Robot twitching and moving without code
Hi our robots drivetrain likes to move even with no code running.
Things we have tried:
  • Different radio
  • tethered controller
  • different controller
  • running in drive mode and not a code as well
We didn’t change brain because it is hard to change but if that is the only option please let me know!
It is on coast code right now. Change it to brake code.
I would write code and then try it.
do you mean it moves when the brain is turned on, and no one is controlling it?
yes when any controller is connected and the brain is turned on it sometimes will twitch and a motor will move on it’s own we have tried a couple of controllers none worked and we did switch radio.
Try updating your firmware and maybe calibrating your controller. And if worst comes to worst, try factory reset.
