Would u rather pick speed or durability
For IQ, definitely speed due to the amount of driver outplay it can create winning you a lot of matches. However, for V5, I would probably try to make an above-average durability bot due to more time and collisions during alliance play. Speed/Durability factors can change based on how defensive/offensive you want your bot to be. I do think if you are forced to compromise one for the other, you should look into a design tweak, as maximizing one at the expense of the other gives you just as significant a disadvantage as an advantage (Also, speed-maxxing bots can sometimes be notorious for being easy to tip and pin, etc)
- why is this in programming support?
- can’t you have both?
I accidentally made myself the guy for this, so
- speed
- durability
While this advice is overall true, it is often not difficult to make a bot that meets excellent durability and speed standards without having to sacrifice from either category in a meaningful way.
What do you mean “winning you a lot of matches”? Doesn’t IQ not have 2 alliances? Additionally, everyone is correct. If you build your drivetrain properly, you should have no issues with durability.
Its only one alliance and they play for highest score
Thank you so much. I really appreciate this. I bet your robot is very good
