We have been working on our code for weeks and cannot find the issue. Buttons 8u and 8d are to be used to make our scissos lift up and down on ports 4 and 5. We tried switching motors, controllers, cortex, remote control…
Here is the code:
#pragma config(Motor, port1, frontLeftMotor, tmotorVex393, openLoop)
#pragma config(Motor, port2, backRightMotor, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port3, frontRightMotor, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port4, liftLeftMotor, tmotorVex393, openLoop)
#pragma config(Motor, port5, liftRightMotor, tmotorVex393, openLoop)
#pragma config(Motor, port6, armMotor, tmotorVex393, openLoop)
#pragma config(Motor, port7, shooterRight, tmotorVex393HighSpeed, openLoop, reversed)
#pragma config(Motor, port8, shooterLeft, tmotorVex393HighSpeed, openLoop)
#pragma config(Motor, port9, intakeBottom, tmotorVex393, openLoop)
#pragma config(Motor, port10, backLeftMotor, tmotorVex393, openLoop)
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(20)
#pragma userControlDuration(120)
#include “Vex_Competition_Includes.c” //Main competition background code…do not modify!
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
// Example: clearing encoders, setting servo positions, …
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
// Insert user code here.
wait1Msec(500); // Robot waits for 500 milliseconds before executing program8
motor [shooterLeft] = 85;
motor [shooterRight] = 85;
motor[armMotor] = 90;
motor[intakeBottom] = -90;
wait1Msec(15000);
AutonomousCodePlaceholderForTesting(); // Remove this function call once you have “real” code.
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
// This is the main execution loop for the user control program. Each time through the loop
// your program should update motor + servo values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to update your motors, et
while(1 == 1)
//Right side of the robot is controlled by the right joystick, Y-axis
motor[backLeftMotor] = vexRT[Ch2]; // port ??
motor[frontLeftMotor] = vexRT[Ch2]; // port??
//Left side of the robot is controlled by the left joystick, Y-axis
motor[backRightMotor] = vexRT[Ch3]; // port ??
motor[frontRightMotor] = vexRT[Ch3];// port ??
//Arm Control
if(vexRT[Btn5U] == 1)
motor[armMotor] = 100;
else if(vexRT[Btn5D] == 1)
motor[armMotor] = - 100;
else
motor[armMotor] = 0;
//Shooter Left1 port 7
/* if(vexRT[Btn6U] == 1)
motor[shooterLeft] = 120;
motor[shooterLeft] = 85;
else
motor[shooterLeft] = 0;
//Shooter Left 2 port 5
motor[shooterLeft2] = 120;
if(vexRT[Btn6D] == 1)
motor[shooterLeft2] = -85;
else
motor[shooterLeft2] = 0;
//Shooter Right port 8
motor[shooterRight] = 127;
motor[shooterRight] = 85;
else
motor[shooterRight] = 0;
//shooterRight2 port 7
/* if(vexRT[Btn7D] == 1)
motor[shooterRight2] = -85;
else
motor[shooterRight2] = 0;
//Shooters mid field
//Shooter left
/*if(vexRT[Btn7D] == 1)
motor[shooterLeft] = 55;
else
//Shooter Right
motor[shooterRight] = 55;
else
//intakeBottom
motor[intakeBottom] = - 100;
/else if(vexRT[Btn5D] == 1)
motor[intakeBottom] = 100;
else
motor[intakeBottom] = 0;
//Lift motor1 Control port 4
if(vexRT[Btn8U] == 1)
motor[liftLeftMotor] = -100;
else if(vexRT[Btn8D] == 1)
motor[liftLeftMotor] = 100;
else
motor[liftLeftMotor] = 0;
//Lift motor2 Control port 5
motor[liftRightMotor] = -100;
motor[liftRightMotor] = 100;
else
motor[liftRightMotor] = 0;
