Shock absorbers for v5
I was wondering if vex pistons could be used as shock absorbers if the output hole was small enough to slow down airflow, kinda like anti slam doors.
I need some reliable absorbers for my intake that falls down.
If you have them on a separate pressure regulator and downregulate the pressure to a specific PSI (through testing), they could function that way. However, the bigger question is: why do you need ‘shock absorbers’ instead of hard stops? Using pistons for this purpose seems unnecessarily complicated.
Thank you, the main reason to use pistons my intake for high stakes has downward force on it by means of rubber bands, If I were just to use like some sort of spring it would counter act the force of the bands but for this use I need it to absorb the impact but not cancel out the force of the rubber bands,
Also Because it swings down from a high point for expansion with the force of rubber bands I need a good absorber (I’ve had lots of bent metal). Yes I know its quite unnecessarily complex
Let’s just say I need a lot more stopping power than a rubber bumper
How about 2 rubber bumpers?
In all seriousness though, how many bands do you have on your intake? Can we see photos?
How heavy is this intake lol?
Without any images of your project/issue - no clue what you need.
But as a general idea, one of our teams used a half of a large flexwheel last year to absorb the shock of a triball kicker. Pretty reliable - many dryfires and no RUDs. Overkill for sure for a falling intake but…
It has 2 rubber bands that are folded over 4 times.
But I actually did not think of that, using a flex wheel is a good solution (although it would be fun to experiment with pneumatics).
I’m not sure why you can’t use a rubber bumper. My team just used two pieces of plexiglass for our last intake and it fell down pretty hard every match. Also, I feel like pneumatics would be a bit overkill (although you’re right, it would be fun to experiment).
My teams intake has problems I think I’m just going to do the flex wheels
