Should this be legal?
I agree with this. They can’t force you into the penalty of touching the platform - thus resulting in an elevated robot for the other side, however, you not taking the opportunity to drive away and touching the platform at the end of the match would be a DQ.
This isn’t gameplay affecting? Since the robot is touching the platform at the end of he match, none of the goals on the platform
“Violations of this rule which do interfere with gameplay, such as preventing a Platform from becoming Balanced, will result in a Disqualification, regardless of whether the interference was Match Affecting or not.”
If the call was that they should have moved away from the platform in the last five seconds (likely), this was indeed the right call. This is not a match affecting scenario as they prevented the platform from becoming balanced".
