Yes. But also I’d strongly reccomend putting the motors at 100% power. Right now you have them at around 45% power
with V5 you should be abe to run them on 45 pct for much longer. i would reccomend printing the motor temp on your controller screen in addition
YES … fix this and other structural alignment problem.
also, only the motor on top is overheating. I swapped them, and even with the other motor on top it still overheated faster than the one on the bottom. Does this mean that their is more friction on the top motor? If so, how can I fix that? I tried widening the holes in the bearing blocks…
Cantilever the flywheel gear, make your gearbox closer to the flywheel, greaseee, make sure no spacers are dragging on the gears. ![]()
