Is there any way someone can explain the slip gear and catapult system to me. I have never worked with this mechanism before and I’m really confused.
many topics on this subject
one of the first ones that searching returned.
The slip gear for shooters have some teeth grinded off of it, allowing it to come back whenever the rubber bands are incorporated. Something to note is to make sure the gear WITH teeth missing is connected to the shaft that is connected to the motor, or the shooter won’t work correctly. You also want to make sure that you have enough teeth off for the shooter component to reach the designated area before the teeth come to contact with the reset shooter, and have enough teeth for lots of power.
