Some basic questions from a newbie Robotics team
I know PROS is very good, but I feel like it should be used only as the compiler (similar to Python 3), with a 3rd party code editor, and for beginners that is when things may be a hard time.
I’ve had nothing but a bad time with Atom. In Turning Point, I switched to PROS and gave it a shot. But during states Atom corrupted the main project and then corrupted the backup project. The same issue happened again during VEX Worlds 2019, not allowing me the capability to tune my autonomous (granted, my autons were almost always bad anyways). I feel like if someone is going to use PROS then they should use Visual Studio instead of the pre-installed Atom. And then if that’s the case now you would need to figure out how to use the command line to interact with the compiler in Visual Studio, and then that is when you possibly will need to rely on the resources of your peers who have figured it out otherwise you will spend minutes, possibly hours searching or using trial and error to find how to download a PROS project onto the V5 Brain using the terminal in Visual Studio.
