The Golden Document: Process for VEXU Vision System
Howdy!
Through weeks of R&D, trial and error, and a lot of summer time on my sleeves, I would like to release a document that attempts to tackle and raise the barrier of the V5 Brain’s functionality. Additionally, the plan is to make the barrier-of-entry be as streamlined as possible for even novice individuals. Therefore, through my research I have created instructions on how to create a computer system in Ubuntu that has the following capabilities:
  • CUDA Computation with a graphics card
  • cuDNN that optimizes neural networks with CUDA
  • Docker
  • CUDA Container to work with Docker
  • Installing Miniconda
  • Installing ROS, or Robot Operating System
  • Realsense SDK for a Realsense D435i Camera
  • Calibrating the D435i Camera’s IMU
  • Calibrating the D435i Camera’s Depth Sensing
  • ORB_SLAM3 for Simultaneous Localization and Mapping with the Realsense D435i Camera
  • Reading data from ORB_SLAM3 to get x, y, z, pitch, yaw, roll data from the camera via a Python script reading the ROS output stream.
  • OpenCV for Computer Vision
  • PyTorch for YOLOv5 functionality and Robot Recognition
  • Using a Logitech C920 Webcam, and tuning the focus on it, for Object Detection using PyTorch
  • A simple communication method by building my own send/receieve functions both with and from the V5 Brain with a mere USB cable
It is important to note that ORB_SLAM3, and any other SLAM method, requires loads of calibration. It may not work the first time and you will need to do a lot of tuning. Good luck!
Second iteration of the Golden Document for Ubuntu 22.04:
What is that top picture?
A 3D map of a portion of my room for reference. The bottom of the 3D map seems to be difficult to see but there are VEX tiles next to a bed, robotics hoodies hanging on the red wall, and a dresser with hats and tech on the right.
Ahh, I see. I still am amazed at AI picture reconition.
