No? Please read the full game manual. Yes the game is “scored” after the end of the match, but the only explicitly stated scoring method that is not counted in autonomous robots in midfeild
Not sure your right on this, although I get where you’re coming from. SC4 explicitly states a toggle is only set to a color when it meets certain criteria at the end of a match
So, while I may bring wrong I believe that even if a toggle is scored in auto it’s wouldn’t be worth anything as it can’t be set to a color before the end of the match. lmk if I’m missing something
I would suggest being careful when telling someone that there wrong and that they should read the full GM, when in fact you could be wrong.
Your belief is wrong and the rule is taken pretty much out of context. First off g3. If only points for having a robot in the mid zone dont count in autonomous, then it is reasonable to assume since it isnt explicitly stated that rollers do not count when counting up autonomous bonus, then it is safe to assume rollers count, as they were not stated to not count
I do think this scoring of toggle in autonomous is worth doing an official Q&A.
Anyone has easy access to the Q&A portal?
thanks
I believe @meng is correct and the question is more than needed to be clarified on a Q&A.
However, I would like to respond to your points. I’m going to start off by saying G3 is not really applicable here as this not a clear cut one side is right the other is obviously wrong and just trying to exploit something. G3 (Have common sense) could be used by either party in a disagreement like this. Secondly, how is taken out of context? It is listed 3 rules before the the rule you’re using . I am not closed to the possibility of my interpretation being wrong, especially sense we are only on version 0.2 of the GM and it is still bound to have some errors. However I would like to know why you think I’ve taken SC7 out of context.
