Tips for scouting for vex vrc and what will be important for High stakes
Feel free to share all ideas for scouting and what you predict will be important next year for High Stakes
Moving mobile goals will be the most I think, that determines a lot of the points. I think that the premise is simple, stack rings for points, move goals, max tier climb
I’m thinking that people are gonna do the high hang early season and then it is going to die down. If you have a fast mid tier hang so you can defend your points in the + zone then go for it ig.
Building off of what @Liam_5405 said, keeping the mobile goals is gonna be really viable in this game while also defending your own or attacking another.
I think also that descoring by like taking the rings off the goals could also be a good idea to look for. This could be helpful for the wall stakes. But moving the stakes could also be a big part of the game. Overall these would be the 2 things I would look for the most.
A spike in high hangs at the start of the season will likely be due to teams not having a mobile goal mechanism to score rings.
Im prolly not even gunna do a high hang. Just probably a 4 bar for lifting goals so they can’t be stolen.
Mogo rush
Being able to score on neutral stake without letting mogo go
Being able to shield negative zone
Having one alliance member go for high hang, or getting them to defend double zone
A lot of it depends on how the hoarding rules work (if it is 1 like TiP, that would make putting 2 in a corner risky as you’d have to let opp take 1 or 2 if 2 opp robots come)
i might try loading goals with a conveyor belt and a like 6 motor drive and then using a slam to get 3 points in 0 seconds so I can guard my goal
