Toggle question
Can I make a pnematic toggle mech so it swings out into place to switch the toggle and it retracts a little so it doesn’t bend or break when it gets hit during matches can I make it so it kinda “hooks” on top of the toggle so opponents can’t switch it
As long as it is not grappling.
We have a simular mech, we call it the X-Hood, but its legal as long as at any point in the match, you can drive away from the toggle, without changing the state of the pnuematics.
Ex. If I had a robot the pushes a couple of standoffs on the back and front of the toggle mech, and it makes it not moveable, but I cannot move away from it without changing the pneumatics state, then its grappling.
Why can’t you? Like a rubber band to pull out a channel that slides on another channel to retract a little and then just normal toggle from there. Legit just do whatever and it’ll probably work if you zip tie/rubber band it enough:)
No that would be considered entanglement to the field under GG something
Do you have a picture of your x hood
