I’m trying to test the Raspberry PIs and Smart Field Controllers with Tournament Manager.
We run competitions using two fields, so that skills run first then matches.
In TM we create an event with one field set for matches (with two fields) and two field sets for skills (each with one field). So in the Field Set Control we have 3 choices:
Match Field Set #1
Skills Field Set #1
Skills Field Set #2
To target a field for either matches or skills I go into Displays->Configure Remote Displays (RPI), select the corresponding RPI and tell it if its a match field (and if so which one) or one of the skills fields.
So far so good. Things display more or less correctly.
The problem is that the field status is stuck on FIELD STANDBY. Even with this status things seems to work, the robots are enabled at the correct times and the display counts down.
I’ve managed to get the status to FIELD ACTIVE somehow. It seems I need to switch the field from skills to match and back again. At least that worked once.
Is there some way to diagnose this? Again, things seems to work, just confusing to see FIELD STANDBY.
There is supposed to be TM dedicated forum, but does not show up for me, so posting here.
