I recently updated the TM software and I am now having an issue with running the TM server on my computer. I run a small VEX U event, and use only one computer to run the field control. I start the TM, choose new tournament, then I get a page asking for an IP and a password. Never got this page before. Previous versions of the TM software no problems. The TM server does appear in the tray, but I cannot move forward. My IT people checked out my computer and cannot find a problem with it on my end. Any suggestions?
Contact [email protected]
If you are an EP, you can also contact your RECF EEM and the chat option on RobotEvents.com when hosting an event.
Other things you can do is also include version of TM you are using, platform running on, etc…
Is event posted on RobotEvents.com?
Insufficient info to debug.
Uninstall and reinstall TM.
Uninstall, new download, install, reboot several times- same issue.
Using a Dell PC with Windows, computer only about a year old. Had an earlier version for Over Under game installed a few months ago, worked fine. Problem showed up after opening TM and doing the latest update.
I run an unofficial VexU for my capstone course , not an official EP. I run several practice sessions on field during academic year. I was setting up to run one.
The TM server is a separate program that listens for network connections. Once the server is started (which it sounds like it is starting), then the TM client needs to connect to it. In your case, this is what is probably failing. If it times out trying to connect, it falls back to assuming you want to connect to a remote computer, which is why you see the IP/password page.
The most likely cause is that your IT has installed something on the machine that is blocking the network connection between the TM client and TM server, like an overzealous virus scanner/firewall/endpoint protection program.
