Tower Bot + Tray vs Tray + Tray
My team personally uses a combination of both color and rainbow strategy. The driver will stack any color and our strategist (me) deducts the most efficient and most point gaining cube to put in the tower. I will then tell my team or the alliance to put a cube or multiple cubes in the towers.
Watch what trays can do as the season advances for the vertical side auton, I have seen some pretty high scoring ones.
I understand what you are saying, but from personal experience, I am much more scared of the double tray than the tray and stacker.
I don’t know about that. So if your opponent is going for colors and your not there is naturally going to be a vacancy in that certain color and you won’t have as much of those colors. This gives control of the field to your opponent which isn’t a good position to be in. They won’t have to look deduce what to do mid match, they just go. If your a tilter your strategy would work, but if you have a tower bot as a partner you need to have a pre made plan.
but as trays advance, so do lifts. lifts will probably continue to be better at protected zone auton.
Thats exactly the point though. While it’s intimidating two trays is gonna be a waste just due to the fact that one tilter can score all stacks possible really quickly leaving the rest of the time to play colors and tilters won’t beat tower bots at a tower fight. There are ways they can counter this strategy, but not effectively.
Actually both tilters stack and then hoard the rest and fight the towers at an albiet decreased efficiency, but is countered by having a significant cube advantage
We will see.
20 chars
We can usually scout out the opposing alliance and find out their strategy just by talking to them. I can usually adapt pretty quickly to different strategies if I don’t know. As for paired with a tower bot, than for sure we would use the color strategy, but in most cases (qualifiers), this is the main strategy.
Edit: We are usually left with 2 cube colors to choose from.
i thin the winner would be tower bot + tray bot because if you had 2 trays you could score lots of cubes, but there wouldn’t be very many multipliers. also, you could only make 1-2 stacks maybe 3 if you are skilled at driving and lucky.
Complex trays are also really quick at towers
Why no multipliers, a complex tray hits every tower, including center, if designed right
You could have a tray bot focus towers, I have gotten scores close to 100 with this strat
I have only seen towers make an auton of 5 tops, I have seen intakes to 7-8 on the vertical side. Besides, cube scarcity is a huge issue, and we have lost by a few points to the at the time skills world champs only due to smart cube hoarding. (Uncharted and the texas skills champs vs us and a B team bot, they won due to an unlucky auton, thanks best of one)
If you make a complex tray you can score and descore towers. Overflow the high one and what we do is just spin and hit the tower causing the cube to fall out. Its risky but if you NEED it then yeah. I think Tray,Tray will do better since they can stack faster than a tower/tray And they can still descore towers too
I feel like it truly depends on the trays, I have a dr4b with a clamp that can hold 4 cubes easily and 5 cubes with a couple of seconds to line up and put it on 8 stacks and then run towers. Then if our alliance is quick enough, they can do the stacks and make short stacks for us to top them as we run towers which we do extremely well.
This is another option. A very situational one, but if the tower bot is big enough…
We prefer to be alliances with another tray to match ours so opposing alliances may be stuck with a less efficient tray or maybe a tower bot. Remember, any good robot you aren’t teamed up with becomes a threat.
