Triangle field element- Legal building piece?
Found this triangle on the legal parts list. Is it the same as the one used on the ringmaster field and can we use it to build our robot?
If it’s on the legal parts list you can use it. That’s what the legal parts list is for.
It doesn’t have the same part number so I wasn’t sure.
I don’t know about the part number difference. Is it something that an inspector will be able to tell?
@MrsBbot – Good point, inspectors go by shapes, not the part number. You should work with your roboteers on matching shapes to the charts / pictures. I’ve had teams freak out because of a part number change. Pictures are good.
