Using an older microcontroller?
What exactly do you mean “connectors?”
Most of the information can be found on the VEX Website’s product page: VEX ARM® Cortex®-based Microcontroller - VEX Robotics
If u need help with a sensor let me know but you should be able to figure it out in the graphical interface of ROBOTC, since I doubt the IDE will allow you to select a non-analog sensor in the analog port in the motor and sensors setup. And from that you can figure out if a sensor is analog or digital for which port to plug it into.
Connor, first of all, I want to thank you for taking time to respond to my question. What I mean is the three wire connectors that plug into the microcontroller analog/digital, interrupt, and motor ports to connect to sensors and motors and such. Thank you for your help wise sage…
Two and three wire cables can be found on the Vex robotics website here: https://www.vexrobotics.com/extension-cables.html?q=&locale.name=English
Robosource has repair parts for wires here: Premium Rubber Bands, Size 64, 100 pack - Robosource.net
kmmohn, thank you so much for taking time to help me. Much, much appreciated. I know this is practically legacy equipment, but it still fascinates me, and I want to learn the ins and outs. Thank you again.
