V5 Brain not recognized on MAC "usb too much power"
Using imacs. and using online Vexcode VR. When connecting via usb, an error comes up on the imac that the usb is "using too much power and the usb is disabled. This is happening on all the computers in the computer lab. When we click on the “brain” icon, and go to connect, no serial numbers appear, so it is obvious the usb is not actually connecting. I also use Spike Lego hubs, connecting with USB and they work fine. I notice on the V5 brain it says radio is vexnet, but that is grayed out. I saw knowledge base article said I should switch to bluetooth with the usb cable, but I cannot get it to switch. Already tried restarts, power off, etc
Is this just happening for one V5 brain ? If so, then it sounds like the USB port on the brain is damaged.
