V5 Motor mount
@railrhodes, this issue of broken inserts was also discussed here: VEX V5 Motor Threads - #4 by technik3k
The best alternative that I was able to find last year was the 6-32 threaded insert:
However, if you couldn’t get those, the next best solution could be to screw a 1" standoff coupler into a broken insert and use a nut on the other end to secure a motor. It is possible, but tricky to secure the coupler with Loctite without further damaging the loose threads. Here is an example:
As @M8R and other have said you don’t want to leave motor dangling on the broken inserts or shifting under even the smallest of the loads, because that could add a lot of friction to the shaft and possibly damage plastic motor base.
