V5 vexcode Pro xdrive
I am trying to code a xdrive on vex code pro but dont know what im doing, i can program tank drive but not holonomic drive.
heres my code
/*    Module:       main.cpp                                                  */
/*    Author:       C:\Users\Daniel                                           */
/*    Created:      Sat Apr 17 2021                                           */
/*    Description:  V5 project                                                */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Leftfront            motor         11
// Rightfront           motor         1
// Leftrear             motor         16
// Rightrear            motor         12
// Controller1          controller
#include "vex.h"
using namespace vex;
int main() {
  vexcodeInit();
   //start by displaying what program is running on the LCD
  Brain.Screen.setPenColor(color::blue);
  Brain.Screen.print("Hello there");
  Brain.Screen.newLine();
  Brain.Screen.setPenColor(color::red);
  Brain.Screen.print("General Kenobi");
    //create an infinate while loop to continually check the controller readings
    while(1){
     Leftfront.spin(forward,Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
     Rightfront.spin(forward,Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
     Rightrear.spin(forward,Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
     Leftrear.spin(forward,Controller1.Axis2.position()+Controller1.Axis1.position()+Controller1.Axis4.position(), percent);
   task::sleep(20);}
It doesn’t seem like you quite understand what to do with the inputs. Check out this video (skip to 0:53 ish). While he is programming with the old cortex, the concepts should help
I sort of understand it but its RobotC, how do i get it into VexcodePro
Your code is correct. You just need to change a couple of ± signs to -. Watching the above video will give you the information you need.
thank u.
next question, how do i get my motors running at less than 100%
For auton? Just type 50 where you have your long equation.
For driver control? Just don’t move the joystick as far.
Or are you looking to create a macro?
Try this: Holonomic drives 2.0: A video tutorial by Cody
