Vex 2020-2021 Competition(unofficial)
turning point
Yeah maybe something like that.
(I really liked it)
it was very fun. made it close calls
I’d say the game is a low scoring game where most points one can get is 100 or less most likely a game in also a that is not zero sum but not many objects on the field.
It’s called submarine rescue. It’s played in the water with the new waterproof V6 components coming out just in time for the parts to show up a few weeks before states/regionals. The main game object is a bunch of assorted plastic pieces that have a possession limit of 3. The plastic pieces are strewn across the deep-end of the pool and they need to be placed in your alliance’s recycling center. The team with the most recycled plastic wins. However, you need electricity to turn the plastic into reusable material. There are also pearls that you can find among the plastic. These pearls can be placed in your recycling center to power them. Each pearl adds an extra 6 pieces of plastic to your recycling center’s maximum capacity. Without having the correct number of pearls in your recycling center, the extra points go to the other team.
That’s my idea. I just made this up on the spot. I’m expecting this game as well as my share of the proceeds made from the waterproof components in 4 years Vex.
Edit: don’t ask me why pearls make electricity. They just do
yeah its usually a pattern. Low/Hi/Low i think
I just want a shooting game
n u c l e a r w a t e r g a m e
Nothing but net mk 2
I just want to build a nice flywheel
Right. We had a stacker game this year so im hopin shooter of a mix of both like turning point
NBN but with foam cubes
I can finally put that cube flywheel to good use!
One game piece: a giant cube. Teams try to flip it so that the top of the cube is their color. At the end of the match, whichever color the cube is wins.
No Auton period.
keep away lol
Basically the endgame of Elevation but without the platform and lengthened to become the greatest 2 minutes of robotics!
Have it shaped like the current cubes so it can land of the corners and the nobody wins
shooting lots of disc shaped pucks across the ground. we’ve yet to see not sphere projectiles. you have to shoot between two pipes, so not directly against the ground, but not high either. you can descore from your opponents goal. back and forth shooting like starstruck but with actual projectiles.
It’s gunna be a back and forth game, we had NBN (net sum), SS (bnf), ITZ (net), TP (bnf), now TT (net)
So it’ll probably be back and forth :slight_smile:
Only auton period :brain:
