With the split of RECF and VEX Robotics, is it clear if VEX will be using the same Judged Awards as they have been using or with the same criteria? The only award listing I can find is in the RECF Library, not on any VEX site.
Vex seems to have an everything is normal just keep competing like nothing happened attitude. And the events listed on the events.vex.com still list all the normal awards, excellence, design, etc. events.vex.com is literally robotevents.com with the recf logo removed.
Given this I would suggest working under the assuming that the rubrics are unlikely to change significantly. A high up at Vex would have to weight in to get a definitive answer.
Hope this helps ![]()
Yes, this certainly helps. Thank you for your input!
To add to this, will Vex events use the same guide to judging, engineering notebook rubric, and judging rubric? I have been working on my EN, and I realized that the rubric that I am using (the current rubric) may not be the one used at events any more since it is licensed by the RECF (I think)
