I am having an issue with my brain being able to recognize the controller. I have tried below options and the controller is still not being recognized. I am using a mac by the way.
Before trying out these options I made sure to verify that the smart radios were plugged in all the way and the cables were plugged in snug.
Option 1 - Connect all devices to the brain and turn on vex os utility software. All the motors are recognized and the controller is not.
Option 2 - Unplug all devices and just have the controller connected to the brain. The controller was not recognized at this point.
Option 3 - Firmware update was performed to all devices with the exception of the controller since it is not being recognized. How do I roll back to a different version of the firmware on a mac?
I really appreciate any pointers anyone can give me in this regard. I will be calling vex support tomorrow to see if there is anything else that I can try.
Are you using the RJ45 tether cable that comes with the robot kit? So, the controller doesn’t work when it’s plugged in via the tether cable? The problem I had was that the controller wasn’t working/pairing in radio mode. It worked fine when tethered. I think mine is due to a bad radio on the controller.
Its possible that during this process my brain is updated to 2.1.3 and the controller firmware is on a previous version. I am using a mac and have the VexOS utility installed. I noticed on one of the pages on the web that the windows version provides a different interface and allows for each component to be updated separately.
Is this possible with the mac version of the VexOS utility?
I think you’d see the tether icon either way. So, bad brain connector, bad ethernet cable or bad controller connector seem like possibilities.
Do you have other brains/controllers/cables so you can find out which by process of elimination?
I was able to get this issue resolved and the problem was isolated to a bad controller. I was under warranty (less than 1 year) and the vex support team replaced the controller. I called in Vex support on Tuesday and the new controller reached me on Saturday.
