VEX V5 Vision Sensor
Would there be any reason that when you go to configure color signatures on robot mesh, the live camera feed in the configure screen says disconnected even when you are connected directly to the vision sensor with the supplied micro USB cable?
Sometimes the connection can be temperamental. Try unplugging and plugging in the USB cable again. Another thing to try (but shouldn’t be necessary) is to disconnect from the V5 while trying to configure.
