Vex vision code with the clawbot
Hello,
So we’ve been trying to make our default clawbot work with vision code, every attempt has failed. Can anyone help with using vision sensors in a clawbot that has its vision sensor mounted upside down? picture is here:
Have you gone through the tutorials on the knowledge base?
we did but still couldn’t solve anything.
You’re not providing much detail on the problem for the community to help you.
Can you describe the problem?
  • Is the camera working?
  • Can you see an image when you connect?
  • Did you create a signature?
  • Does the device return a value when you test a shape?
  • Will you share your programming?
