Is anyone else having trouble getting VEX VR to work with Chrome?
I am running an assessment with students using my VEX VR license. My students access VEX running MacOS and use a chrome browser to run the program as Chrome is mentioned as a supported browser.
Several months ago, VEX VR stopped working on chrome and my IT department discovered that the ZSTD flags in chrome needed to be disabled. This resolved the problem.
Chrome’s most recent update has removed these flags so once again my students can’t access VEX VR and can’t disable ZSTD.
This is the first I’ve heard of any issue regarding ZSTD from any users.
I would suggest you replicate the issue (which I assume is the VR Playground not loading? Or is the entire site not loading) and then submit feedback within VEXcode VR so we can take a look at the diagnostic logs to see what the issue might be.
VEXcode VR is served via a Cloudflare CDN system since the entire system runs within your browsers (there’s not any server side processing happening - all playgrounds / code execution runs completely within the browser context) - so I’m curious if something is happening from the CDN side, as VEXcode VR doesn’t utilize ZSTD in any capacity on its own.
So the entire site doesn’t load. I think it’s a problem our side. Basically, our firewall can’t inspect ZSTD packets and as such rejects them. They plan to upgrade our firewall firmware over Christmas break but until then I’m locked out.
(You should note that networking isn’t my background so excuse where I don’t understand things. I’m mainly coming from a teaching perspective where things are no longer working!)
Since it seems to be a networking issue on your district’s end, there isn’t much we can do at this point to help.
As you are a VEXcode VR Premium subscriber, I would recommend using the offline versions of VEXcode VR that should keep you up and running on your Windows or Mac devices:
