VEX VS Extension CPP Versions
What is the latest version of CPP that is supported by the VEX VS Extension?
I believe there is an extension for V5 that you can download in Visual Studio Code that works similarly to VEXCode Pro.
Visual Studio Code Link
Download Visual Studio Code - Mac, Linux, Windows
VEX Extension Link
VEX Visual Studio Code Extension - VEX Robotics
I am currently using the VS extension and have the compiler running c++11, I am just curious really if c++20 is supported or not, as last time i checked (on vexCode Pro, however) c++17 was the most recent version of C++ that was supported.
VEXCode and its VSCode extension are currently pinned at C++11 due to the way that it links to it’s stdlib. If you need newer language features, you can update that in the makefile, but everything in std will still use the cpp11 version libstdc++. If you need a newer version of std, then your best option is switching to PROS.
or just install your own toolchain.
You will however tend to create much larger executables which may not be practical to download wirelessly.
