Vex Website Low Strength Gears
Does anyone know where I could find the low-strength gears on the vex website? I want to buy some normal 60 tooth and 36 tooth gears to gear down a drivetrain, but it doesn’t seem to be in the gears section. Did they end up discontinuing it?
You need to buy the Gear Kit (276-2169) from this page. Gears - VEX Robotics
They do not sell them separately.
I believe that all the high strength gears come with the slip and lock inserts, making them compatible with regular/low strength shafts. If this is not the case, you could buy bearing inserts to go with your high strength equipment.
I think they’re looking for the thinner ls gears, which only come with holes meant for ls shafts.
Saw a HS gear in half. Now you have 2 LS gears!
I’ve never bought ls gears separately as my old team just had a bunch of them sitting around. Now I know. Thanks for clearing it up!
