VEXcode V5 4.60
VEXcode V5 version 4.60.0 is now available. It can be downloaded here: VEXcode Install V5 - VEX Robotics
The VEX Library’s New Features in VEXcode V5 4.60 shows off all the new features in this release.
Change Log:
  • Redesigned Python and C++ toolboxes with collapsible sections, syntax highlighting, and category icons for easier text coding.
  • Reorganized Blocks toolbox with clearer categories, subcategories, and updated groupings, plus active category highlighting so blocks are easier to find.
  • Updated block color themes for better readability and accessibility.
  • Added string blocks for working with text in Blocks projects.
  • Split the Looks category into separate Console and Screen sections so print commands and screen controls are easier to find.
  • Combined math and comparison functions into a single, streamlined operator block.
  • Improved download speed for Python and Blocks projects.
  • Refreshed app icons with brighter, higher-contrast colors for better visibility.
  • Brain Information now shows Console Serial Port status, and Print Console displays an overlay when the port isn’t connected.
  • Added the ability to save and copy images from the AI Vision sensor video feed.
  • Improved code colorization for Optical and Distance sensor enums in text projects.
  • Simplified generated code when printing variables and Boolean values.
  • Added support for the V5RC Push Back AI classification model on the AI Vision sensor.
  • Android minimum system requirement is Android 9.
  • FireOS minimum system requirement is FireOS 7.0.
  • Chromebook minimum system requirement is ChromeOS 100.
  • iPadOS minimum system requirement is iPadOS 16.
