VEXcode V5 C++ cannot compile
One of my teams is unable to compile / build any C++ text project in VEXCode V5 on one of our laptops. I have installed VEXcode V5 4.68.0-latest (the x64 version).
Whenever I try to build a project, I get the following error:
Error compiling your program.
windows build for platform vexv5
"CXX src/main.cpp"
make: *** [vex/mkrules.mk:13: build/src/main.o] Error -1073741515
make process closed with exit code : 2
I have done the following troubleshooting steps:
  • Uninstalled VEX drivers and VEXcode V5 (through Windows “Add or remove programs”)
  • Rebooted the computer
  • Installed the latest VC_redist.x64.txt package from MS
  • Re-installed VEXcode V5 (latest installer downloaded from Coding with VEX)
The following steps will re-create the issue:
  • Open VEXcode V5 on the computer
  • Create a new C++ project
    • File → New Text Project
    • Select “C++”
  • Click ‘BUILD’ from the toolbar
The same failure occurs when I open a C++ example (like the “Competition Template”).
I do not see the error when I create a Python text project.
Is this a known issue or have I uncovered a new way for computers to make our lives … exciting … ?
Thanks!
That type of error is nearly always associated with the C++ runtime, try loading the older one I mention in this post..
There’s no compiling with a python project, we send the Python source directly to the V5 brain.
