VEXcode VR is Now Available!
Changes for 4/10:
  • Adjusted blinking speed to increase visibility with “Step” and highlight execution features
  • Adjusted behavior where “When Started” will blink when highlight execution of a project
  • Adjusted behavior for the “Step” feature to automatically step through the “When Started” block and save the need for an additional “Step” action
  • Resolved an issue where a project would always “Stop” after completing the last command in the “When Started” stack
  • Updated the icon in the toolbar for the “Playground” button
  • Playgrounds: Corrected the hazard border on the “Castle Crasher” Playground to be red instead of yellow
Older iPads can sometimes run into memory issues. You can try force quitting Safari and reload the page afterwards. If you continue to have issues, I’d encourage you to have your students use the Feedback tool and let us know so we can look at diagnostic info there.
What is the objective for disk transport?
Also a undo button would be great. Just lost 45 minutes worth of code by acedentaly deleting it… :rage::rage::rage::rage:
I’m pretty sure that you have to put the colored discs in the correct areas. But it is mostly for getting to know the electromagnet
Is there anyway I can make my “vacume” not retrace were it already was? Here is my code and the lines of what it does after about 4 minutes of driving
These will be added to the activity sites very soon…
Right-click (or long press on tablets) to bring up the context menu. Undo / Redo is available from there.
OMG THANK YOU!
There is already an undo function. If you long press or right click in the workspace, you will get a menu that has undo and redo. If you have a keyboard, you can also use the standard undo/redo keyboard shortcuts.
We are aware that a lot of users do not know that this exists, and plan to implement a change to make it easier to use the undo/redo features, but we do not yet have a timeline for this.
Is there a way to locate the robot within a playfield outside of resetting to the playfield default position?
Is there a way to use my blocks created in one project in another project?
There is not a way to manually position the robot (beyond programming it) as of today. There may be multiple "starting points " in the future for different Playgrounds.
You can’t export the My Blocks from one project to another, but you can save a copy of your project and then modify it from there for additional projects… think about making a base or template program that has your MyBlocks in it for future use.
Is there ever going to be a text version?
You can use a polygon to drive in a “circle” or arc. A 20 sided polygon visually looks the same as a circle on the Art playground.
My students using iPads when they click on save to your device it downloads a .txt file instead of .vrblocks. Do you have any idea how to fix this?
It probably is actually downloading the file as filename.vrblocks.txt, because Safari.
If that is indeed the case, you can simply remove the .txt to be left with the correct filename.vrblocks. I am not sure how or even if you can do that on an iPad, though.
Try a different browser, such as Chrome.
Students were told not to use Safari because of the problems reported. File that is downloaded is literally “document.txt”. I have opened those files in a text reader and it is a VR Block file which I verified by changing the extension on my laptop to “.vrblocks” . I have also duplicated what my students have done on my iPad using Chrome. Even if I change the name of the program on the website from “VEXcode Project” to something else it still downloads as Document.txt
On iPads, you should use Safari. Chrome’s implementation makes it (currently) impossible for us to save the .vrblocks file type correctly. This is something we’re continuing to investigate, however.
I’m not currently aware of any issues on Safari - can you describe what you’re seeing that is causing the problems?
Just the issues that you have eluded to in the past couple of days concerning older iPads. My students school issued iPad are approximately 3-4 years old. Along with Barin’s response which I now see have been edited. Plus the update post approximately 5-6 days ago.
