VEXcode VR Rapid Relay Inconsistent
the VR system is so frustrating to use. When the robot goes into the final loop, the bot usually scores, but it only might make it in (everything is pretty much random) but it like slowly drifts to the side and ends up missing its so frustrating please help its like random whether the ball will go in or not like sometimes I’m on a roll and I get quite a few points but then it just misses other times it misses right away
Welcome to the forum! I know the anger towards Vex VR, I feel the same way. What device are you running your code on? From personal experience Chromebooks just aren’t very consistent and if you need to use it then make sure it has at least 80% battery and keep it plugged in. If you have access to another computer, try your code on there to see if it’s any better.
Hope this helps!
I ran it on my chromebook fully charged and plugged in I ran it on an ipad and then I ran it on my desktop a bunch and it works so much better on desktop I never go below 59 frames but its still inconsistent
