Because of the pandemic, our team has operated out of two separate locations, and we created two separate robots for doing driver skills and programming skills. We believed this to be legal due to the wording of VUG1:
<VUG1> Instead of a 2-Team Alliance format, VEX U Matches will be played 1-Team vs. 1-Team. Each Team will use two (2) Robots in each Match.
- a. Teams are allowed to build as many Robots as they would like, but only two (2) – one of each size – may be brought from the pit to the playing field for any Match.
- b. All Robots must pass inspection before they are allowed to compete.
However, in the week leading up to our final skills tournament tomorrow, we recieved an email saying that they will only inspect 1 robot, and cited rule VURS1:
<VURS1> VEX U Teams are only permitted to use one (1) 15” x 15” x 15” Robot, i.e. Robot B as defined by <VUR1>.
This rule references <VUR1>, which is:
<VUR1> Teams must build two (2) Robots, subject to the following size restrictions at the start of the Match:
- a. Robot A must be smaller than 24” x 24” x 24”.
- b. Robot B must be smaller than 15” x 15” x 15”.
We emailed back about the legality of having separate robots for prog and driver, and their response was that if it was legal they would allow it, which is not a very comforting response.
Previously, <VURS1> had permitted for both Robots A and B to be used in a skills match, and was updated to only allow Robot B in the May 25th Game Manual Update, which we believe to be the reason why it emphasizes “only 1 robot”, as opposed to having 2 robots running at the same time. <VUG1> explicitly states that having extra robots is allowed, but that only 1 of each size is allowed per match, so would it not make sense that that ruling applies to skills matches as well, and that you’re only allowed one 15" in a skills match?
Unfortunately, the Official QnA is closed, (and a response probably wouldn’t arrive in time if it was), so the best I can do is ask here, and ask for further evidence so that if the refs interpret it as illegal, we can prove to them that this is legal. The refs at a previous tournament didn’t have an issue with this so we thought it’d be fine, and I haven’t done enough driver practice with the programming skills bot to just run it as the sole robot.
