Hi! I need help scoring. How do I get the beam to lower, the ring to come off the beam onto the goal, and then bring it back up. I work in blocks btw.
Use the motor turning blocks. The motor to move “the beam” is “ArmMotor” and the way to get rings off is “PusherMotor”
it asks for a degree. What’s the minimum?
I don’t remember the exact numbers, but somewhere around 360 worked for moving the arm into a scoring position, and I used the one without degrees for the pusher. To grab them, go up 30 or 40 degrees at the start without waiting (by clicking the arrow) and down the same amount down when over a ring.
How do you disconnect the mobile goal from your bot
How do you connect the mobile goal to your bot
just drive into it and it should snap into your robot. From there you’ll be able to drive and turn with it
Once you have it connected just reverse the drive and it should disconnect it from the bot
