This thread will be used to publish updates to the VIQC Slapshot Game Manual.
Please start a separate thread in this forum for unofficial discussion of any of these changes. For any official questions, please post in the official VIQC Slapshot Q&A.
On June 14th, 2022, Version 0.2 of the VIQC Slapshot Game Manual was released, and the following changes were made:
Updated links for the Code of Conduct and Student-Centered Policy.
Corrected Figures throughout the Manual that showed an incorrect version of the Yellow Dispenser.
Added a Figure number to the Violation Flowchart (Figure 4), and updated all sub-sequent Figure numbers.
Updated the weight of Discs to 0.02 lbs (10 grams).
Added a new drawing to Appendix A to note the proper way to assemble the Purple Dispenser.
Minor typo fixes.
The next manual update, Version 1.0, will occur on June 28th, 2022.
On June 28th, 2022, Version 1.0 of the VIQC Slapshot Game Manual was released, and the following changes were made:
Corrected Figures throughout the Manual to show the Purple Dispenser Arms in their starting position (contacting the bottom-most Disc)
Added a new drawing to Appendix A to note the correct starting position of the Purple Dispenser Arm
The next manual update, Version 2.0, will occur on August 2nd, 2022.
On July 19th, 2022, Version 1.1 of the VIQC Slapshot Game Manual (an unscheduled update) was released, and the following changes were made:
On August 2nd, 2022 Version 2.0 of the VIQC Slapshot Game Manual was released, and the following changes were made:
Corrected Figure 9 to accurately display the boundaries of the Contact Zones and Goal Zones
Added a Blue Box to SC5 to clarify intent
If a Dispenser is “triggered” by a Robot and a Disc incidentally lands in a position that partially meets the definition of Removed, Teams will generally be given the “benefit of the doubt”, and the Disc will be considered Removed. It will be at the Head Referee’s discretion whether this interaction was truly incidental (such as in Figure 14), or due to an “incomplete trigger” by the Robot (such as Figure 15).
Added two new figures to SC5 to clarify intent, and updated all subsequent figure numbers
Added a new bullet point to R13 stating that it is legal to bend parts which are intended to be flexible
It is legal to bend parts which are intended to be flexible, such as string, rubber bands, or thin plastic sheets.
Replaced T15 with a new rule stating that Fields may be repaired at the Event Partner’s discretion
Added rules for Live Remote Skills to Appendix B
The next manual update, Version 2.1, will occur on October 4, 2022.
On October 4th, 2022 Version 2.1 of the VIQC Slapshot Game Manual was released, and the following changes were made:
[blue box]
If a Disc is launched by a Robot after the Match has ended, it will be removed from the Field by the Head Referee, and not considered Scored. This is the only Disc that is affected; all other Discs will still be considered Scored, even if they were impacted by the post-Match Disc. See this Q&A for more information.
Updated G6 to clarify that a Team utilizing a single Driver may only drive during the first thirty five (0:35) seconds of the Match.
Updated Appendix B to include Robot Skills Challenge Rankings for League Events
The next manual update, Version 2.2, will occur on December 6th, 2022.
On December 6th, 2022 Version 2.2 of the VIQC Slapshot Game Manual was released, and the following changes were made:
The next manual update, Version 3.0, will occur on January 31st, 2023.
On January 31st, 2023, Version 3.0 of the VIQC Slapshot Game Manual was released, and the following changes were made:
A Team’s first instance of Scoring a Disc after the end of the Match will be considered a Minor Violation, regardless of whether the Violation was Score Affecting or not. Subsequent Score Affecting Violations of SC1 should be recorded as Major Violations and Disqualifications.
Updated Figure 17 to clarify Expansion Zone boundaries
Minor typo fixes
The next manual update, Version 4.0, will occur on April 4th, 2023.
On April 4th, 2023, Version 4.0 of the VIQC Slapshot Game Manual was released, and the following changes were made:
- Fields will be elevated 16” off of the ground.
- The full Robot Inspection Checklist can be found here.
The 2023 VEX Robotics World Championship will consist of the following divisions:
- VIQC Middle School: 10 divisions
- VIQC Elementary School: 10 divisions
To determine Division Champions, each division will play as a separate standalone tournament.
- Teams will have 10 Qualification Matches.
- Finals Matches will follow the standard format laid out in rule T13.
- 20 Teams / 10 Alliances will play in Finals Matches of each division
To determine the World Champions, the Division Champions within each grade level will play a single set of Finals Matches, per the standard format in rule T13.
- Other than the seeding purposes listed below, scores from the Division Finals are not used in the Overall Finals (i.e., it is a “full reset”). For example, if an Alliance achieves a lower score in their Overall Finals Match than the score that won their Division, the Overall Finals Match score will be the one that is used to determine their final ranking.
Division Champions will be seeded for this tournament using the following criteria:
- Alliance score that won their Division
- Sum of the two Teams’ Qualification Match scores
- Random electronic draw
Any warnings or Minor Violations given during Division Matches will persist into the Overall Finals, just as they would persist between Qualification Matches and Finals Matches in a standard tournament.
Note: Crossing “through” (instead of “over”) the Fence is not permitted at any time.
A Robot achieves a Contact Bonus if any part of the Robot is contacting the Floor inside of a Contact Zone and the Robot is in contact with an Expansion Zone.
Note 3: If a Robot is touching a Contact Zone but not an Expansion Zone, no Contact Bonus is earned by the Robot, and the Match Score is not increased. Rules still applies, as may rule if the Robot expands. However, since no Contact Bonus is earned, this action by itself does not constitute a Score Affecting Violation of G14.
VEX IQ Smart Cables may only be used for connecting legal electronic devices to the VEX IQ Robot Brain.
