Is there a way to Bluetooth a vision sensor and/or a ai vision sensor onto a chromebook so you can see what the sensor is currently seeing wirelessly?
There isn’t a way to do this to my knowledge with the original vision sensor with any computer, including a Chromebook, through bluetooth. However, you can see a live feed from it through its own wifi connection apparently. Never done it before though.
When I use the wifi, the sensor doesn’t connect.
Refer to this website to help you set it up: https://kb.vex.com/hc/en-us/articles/360055918272-Connecting-the-V5-Vision-Sensor-to-a-Wireless-Device
I can’t give directions since I’ve never done it, but this website should help a little bit. Let me know if you have any issues. If you are using a device with mobile data, disable it before connecting to the sensors wifi.
Thanks, it works now!
Not a problem. Good luck!
