We were working on our lift and we were wondering what the weight of other robots are.
Our robot is 7.6kg or about 16.76lbs
Some can be pretty hefty. One of the 9791[a-f] weighs in a little above 30 pounds.
Depends also if you use all Aluminum or all Steel
Our robot is all Aluminium so it will be much lighter
Mine will end up around 26-28 pounds including a lift but we plan on lifting and not being lifted.
My robot will end up around 16 - 18 lbs depending on whether or not I try for a lift.
Our robot (241N) weighs in at just over 12.5 lb, with batteries and everything. (No lift)
Ours is ~17 lbs, but we’ll be shaving off some weight before nationals. No lift.
That is light for a lifting bot. Can You do a high lift?
Our lifting bot weighs in at just over 28 pounds.
That is quite light for a lift bot. Just noting that in 62’s reveal/teaser, his high lifting robot is less than 20lbs
Our robot is currently ~13 pounds without a lift. We will be adding one in the next week or so, so that weight will go up a bit.
My previous robot was about 18 pounds with no lift, and could be lifted by a sideways fourbar powered by two 5:1 393s. My new robot might weigh about the same or even less with a lift.
I think our robot is the lightest here, but with batteries and everything, i have a robot that moves 4 feet per second and it weighs in at 11 pounds. We are planning to be lifted so we made everything out of aluminum and shaved off everything unnecessary.
Our robot weighed in at 19 pounds.
Our last one was about 18lbs, but with the lift added (that actually worked well) it was so heavy that it could not drive more than a few feet before stalling.
Currently, our robot weighs in at about 11.5 pounds (without a lift). We have plans to decrease the weight before Worlds.
With a lift, our robot weighs in at about 13.5 pounds.
@Ryan C. (Team 8000) That is extremely light for a lift bot. Would like to see design.
@Mr. Vex We plan to post a reveal a few days before Worlds. PM me if you have any questions.
In default configuration it is 20 lbs, but could high lift 25-30 lbs robots with additional counterweights.
Our robot is 22lbs without a lift
darn you transmission system!! ![]()
Ours is about 40-45 Pounds
