What is better? CORTEX hardware OR V5 Hardware (Super clawbot)?
I am currently in the process of making a robot for a SkillsUSA competition and saw the CORTEX© based Super Clawbot and i got curious; would the original CORTEX hardware be best (original version) or would replacing it with V5 work?
For reference, here is a picture of it (below):
I personally haven’t competed in Mobile Robotics, but have been around enough to know a few things about it. We had a team use this exact build instructions for the lift and claw. They used v5 motors and it seemed to work pretty well. Good luck at Nebraska Skills USA! Might see you there!
Good to know that you might be there! I am unsure whether or not the brain will fit, but if not then it’s fine because im using a track based drive-train which has a V5 workcell baseplate screwed on top which means i can place the brain and the battery on the bottom without problems.
funnily enough I might be using a CORTEX claw for my competition robot because my school district has nothing for my new team other than V5 Motors and Brains
Quick Update:
  • The robot drive-train changed, it is now using 4-inch wheels.
  • the robot bracket is half-way done, i just need to make the arm and the other side.
Im probably a little bit late in replying into this but I had someone build this with v5 parts like the motors and the brain and it worked really well
Youre never late to reply! also good to know, did you take it to a competition (such as the SkillsUSA Robotics USAR competition)? would love to know that!
Semi-final update:
  • Completed the bracket for the shoulder, it is attached.
  • completed shoulder arm, it is also attached.
  • completed the hand mechanism which includes the wrist mechanism, the claw, and the Ultrasonic Range Finder bracket with the URF attached.
All that’s left to do is:
  1. attach the hand/elbow arm
  2. connect the last of the wires (the rest were already connected)
  3. program the robot and download
  4. complete an engineering notebook for the competition.
This was all very worth my time, and I pride myself in working with VEX so thank you all for the support, even if you dont feel like you supported! Also good luck to 1064B if they do show up at the competition, would love to meet in person!
The Final update for rhe robot is ready!
  • I have attached the elbow arm/claw
  • all wires are connected and can move freely at full expansion
  • I have started making entries for the robot in the engineering notebook.
This was an inspiring journey for me and my partner, and I will share some photos of the completed robot soon!
