My team is making a catuplt and we are deciding if we should use a intake system or a claw, I am trying to convicne my friend to switch to a intake sytem, is an intake system actualy better, or the claw, I am open to change my mind.
I would use an intake because there’s a lower chance of it breaking.
I’m a V5 competitor, but I help coach some IQ teams. I’ve seen both done before, so I’m not gonna tell you a direct opinion but here’s what I’ve seen:
For catapults, they are quick to grab bean bags and launch them to level 2 and level 3 accuracy (if assembled correctly). Sometimes the catapult can get off by a little bit, so I’ll say it’s not quite the easiest to get right. Often beanbags will land in level two and three, sometimes one, so it’s a nice way to accumulate many points. Only downside is that you can’t use level four and sometimes beanbags landing on top of others will slide down to different levels. Usually don’t see the second part as too much of an issue.
For an intake (I’m guessing you’re talking about one that kind of works like flop, or just takes a beanbag in and drops it?), it’s slower because you have to go all the way back-and-forth to put the beanbags down onto the platform. Definitely more accurate though; if it extends far enough, most can land in level three. If it extends enough, can also reach level four. You would just have to make it easy for the robot to cross that bump and travel under the little bar.
Honestly, both are ideas that work really well, as long as the build is done correctly. I’ve even seen teams that utilize both (for example, catapulting at the levels, and using an intake that extends up to level four). Whatever your team decides, I’m sure it’ll be great ![]()
I’m pretty sure the OP means the loading system for the catapult.
@5020_Offical The claw will only break if poorly built. You can theoretically build anything without it breaking, as long as it’s built correctly.
OP @Whyistherenooptions: Welcome to the forum! Your choice depends on your robot design and limitations. An intake requires a motor, however, most claws only require pneumatics. You should also see which one will be easier to manage/attach, and which one will work better with your robot design.
