What is the best “claw”?
When I say claw I mean like a roller or a lift.
So I have been building our intaking claw and i have been thinking, what is the best “class”? Personally i think it might be something with a roller or flex wheel.
There is no “one class” that surpasses every other design. Ultimately it’s up to team preference, and more importantly, what your drivers would like to use. However to entertain your question…
I have been theorizing about a flex wheel roller (like you would’ve seen in Push Back Worlds) into a little conveyor that pushes the pin/cup stack into a claw, which then lifts it. Of course, that’s a lot of gears & bands, so it’s complex, but it’s worth it in my mind.
What are the pros and cons of each design? What designs are better or faster?
That sounds like a great research question for your notebook!
Play around with mutiple variants of each design you can come up with, and document your findings. Not only will you find the answer to your question for your specific preference, but it will also elevate your notebook.
Good luck!
They find out the best claw is doing four pins and five cascade wires to secure them in place. Wires being five mm to six mm in thickness and to have diameter of three centimeters for the pins. Then you make a claw of three instead of two pincer grips to allow for pincer hold to be better. Then master it using five robotic programs
  1. pincer ai
2)pincer ai grippers
  1. Diagrams of pincers and videos and how to hold it
Then to make the ai have processors in the arm and head
To make the head have one processor like a CPU and to make it have video antenna wifi connections
To allow it to see and process the ai of the claw to hold things more precisely
And to make three pincer robotics this way
And to do a claw
If do a claw arm like a crane then all by means still do same way but do it with claw precision’s like pincer ai etc
