What is your favorite / most versatile VIQ part?
Parts are the lifeblood of any robot. VIQ is hard because roboteers are not allowed to cut, bend, shape, weld, glue, etc. new parts. Some of the parts are go to items. What is your favorite part to have??
Mine is
I love them, I use them all the time since I have the inability to count, so I’m off by one all the time. These let me fill in the gap. Not only good for Standoffs but also good for corner connectors. You can also use them on the end of axles for ones that are don’t have a heavy load. (Yes they make a version with a square inset, they are hard to get in a large supply)
One thing that would be great to have is the extender that had a 2x pin on the end. Being able to connect two parts AND get a connection for a standoff or corner connector at the same time would be a bonus.
What is your favorite part?
For me, it’s a split between the standoff extenders (love their use for allowing an axle to spin without also having to spin inside a plastic hole with lots of friction generated like the shaft bushings), and metal motor shafts.
The metal motor shafts have made such a difference in properly building a good drivetrain that won’t have things fall out over time. The only issue I run into is getting kids to put washers in the right spots. I think I’m going to be making a poster to put on the wall ahead of next season…
Oooh. Fun question. I have 2 answers.
IQ answer:
2x Wide, 2x2 Corner Connector (228-2500-134)
I used like 20 of these on my bot last year. They are a low profile chassis corner and are useful everywhere.
VRC answer:
1x1x35 aluminum angle. This stuff is a go-to for lightweight, easy, and strong connections. A good versatile piece.
I suggested this to them years ago. I’m glad they finally appeared.
Capped or with the ring? Unless I have a special reason, I hardly ever use the plain ones. Never attach to a motor unless it’s a ringed axle.
I do wish they would come in longer versions, but I can cope with it.
I’ve wished that the shaft couplers would be made legal, but the four gears connected with 2x2 pins works too.
I think this is my favourite part
The ones with the rings (red, blue, and green).
Capped shafts have interesting uses, especially when I realized you can trap them between two pieces (with one washer), and keep the axle from slipping out at all, and it still spins like a dream. Great for some uses with the long capped shaft pack, but way more situational that the metal motor shafts.
I love the white capped pins.
I’ll vote for the already mentioned metal axles, both the capped and but especially the ringed ones.
I don’t know how many times I’ve had to show a student that putting more stoppers on the outside end isn’t helping.
Would also add my vote for some longer ringed axles.
I use the large chassis corner connectors a lot.
Screenshot 2024-03-24 195825
I’m so glad the Full Volume has so many of thoes and @Micahy321 's one.
How would you use the ball and socket joint is VEX, And what’s the purpose of the trusses
I’m assuming when you say ball and socket you are talking about parts 228-2500-1689, 228-2500-1664 or 228-2500-1665. I’ve used them with the shocks to keep things lined up. If you build the classical rack and pinon steering, they can be used to be the tie rod connections.
There are a number of parts that have truss in their name. The strongest build uses triangles as the support. All of the truss parts let you build triangle supported structures. There are a large number of triangle truss plates in the wild (parts of a prior game). They work well in builds with a tower / back.
The VEX ball and socket joint facilitates precise movement while maintaining stability, making it essential for constructing reliable robotic mechanisms. The purpose of a trusses is to distribute load. hope that helps. :wink:
Let me tell you… MY FAVORITE POART IS 228-2500-090!
the truss peices I’m talking about are the peices that are 5-6 pitch lonc and are ( shaped with a half pitch rise
