What's the difference between normal gear and hybrid gears?
Some one says that hybrid gears give huge benefits to 1:2 drivetrain. We couldn’t find lots of information about hybrid gear? Can any one kindly explain?
Hybrid gears are a combination of bevel and spur gears, allowing them to be used as one, the other, or both at the same time.
@Sidoti did a really good explanation here, including gifs, which are much better than words in this case.
For a split second I thought you are referring to this gif :slight_smile:
But, yes, @Sidoti did a great job explaining hybrid gears!
I used hybrid gears to build a vertical motor drivetrain back in slapshot, which is a great use of them. Here is a video. https://www.youtube.com/shorts/9DzZ6N2NNJo
