Where would I locate a strafing wheel
Hi, I’m going to assume you are using epicyclic gearing for your transmission. An alternate would be using the relative directions of your motors as a shifting, but that would be pretty terrible. Epicyclic gearing also has the nice advantage that it creates an infinitely variable transmission, which benefits acceleration time.
The first epicyclic transmission I’ve seen in vex was all the way back in 2013, by Stanley Shi - so its certainly nothing new.
He used a planetary, and depending on if the inputs go the same or opposite direction, the mechanical advantage changes (though I don’t think he coded the IVT part). I know at least one team developing a drive with this chain style of planetary.
An alternative to using chain is a style of epicyclic gearing that uses two suns instead of a sun and a ring gear. The closest I’ve seen to this is before I started working on them is 5327’s spur gear differential, but they used it for power sharing rather than variable MA, and I know another team now designing this style of drive.
Here is one of my cads for one of these transmissions. I’m assuming you’re doing something similar for a nonshifting transmission, and if you aren’t you probably should be.
It is wrong to say you can’t use a multispeed transmission on a holonomic drive, but it’s decently viable if you’re already doing a similar transmission.
Here is a cad of a 6m multispeed holonomic, and its movement profile. The third motor on each pod loses one direct component of movement (of longitudinal, lateral, turning). In this case it is strafing, but it could also be turning or strafing depending on which differentials you link. A 5m drive would lose 2.
Now this drive may certainly be very impractical, but it is certainly more practical than wasting friction and time on a transmission just to throw your traction away, when applying more force and lower speeds is the whole point of a transmission.
Edit: You pretty much have the stafe wheel location figured out from your original post.
