White field bending when trying to toggle
Hello, i’ve encounter a major issue during competitions and scrimages where the white field bends a lot when I try to toggle the toggle using a passive mechanism. Since I use the black metal field, I don’t have that issue as it doesn’t bend as easily. Is there any solution I can do to fix this issue when using the white fields?
Hello! I am sadly a bit unknowledgeable about this topic, but I may be able to help. Naturally, the white fields are going to bend more since they are made out of plastic. However, to ensure that the bend as little as possible, there is supposed to be straps that go through the bottom of the field to each wall to keep it tight (this is for the portable fields, AKA the white ones, I am not sure about the older metal fields.) Make sure for the white fields that those straps are being used, and if they are, make sure they are very tight. I had a similar issue when I was on a different team for High Stakes, and that ended up being the cause of it.
