Hi, I noticed that instead of banding a lift a lot so only 11W of power is needed, most teams band minimally or not at all, and use 22W of power. Why don’t people just band the lift a lot more to minimise motors and maximise payload? I understand that banding can lower height accuracy, but a well-programmed multi-stage PID can fix that.
Sometimes they use 22 watts so the lift has more torque, and sometimes they just don’t realize that they need to do more banding. The accuracy thing is true, but I think that the main issue is teams doing the banding incorrectly.
Cause then the motor has to fight all those bands on the way down.
The main reason is there’s no easy way to triangle band a cascade lift to achieve near constant force. This means when the lift is fully down, the bands will be very tight and the motors will struggle to lower, and when it’s fully up, the bands will be completely loose. There are some workarounds like using long pieces of latex tubing wrapped through each stage.
A good amount of teams do band their cascades. I can’t speak for everyone else but my team doesn’t band ours for a couple of reasons.
- Banding is solving a problem that doesn’t exist for us, banding doesn’t make the lift faster, only easier to lift, and currently it does not struggle to lift all the way at all. So, banding wouldn’t really make it better.
- Our lift currently comes down without a string pulling it down, if we were to add banding we would almost certainty need a string to pull the lift down.
If your lift is struggling, there is probably a lot of friction in the lift, while banding is a possible solution, the need for banding could reveal the lift is poorly built. That said this is really case by case, your lift could be built perfectly and banding might be the best solution for you.
