Wireless Serial Communication for VEX V5 in PROS
Hello VEX forum. I want to establish wireless serial communication between a V5 brain and a PC running supervisory code, with the V5 brain being programmed with PROS. Can this be done using the existing robot radio or does another serial communication method need to be used?
I’d put a raspberry pi on the robot. Then use wifi connection between onboard raspi and your computer.
Thanks for the suggestion. I have access to a raspberry Pi so that is perfect. Do you have any links to a guide for using one or another project which did something similar?
