Writing text to the terminal?
As far as I can tell, writing text to the debug window is no longer possible in vexcode like it used to be back in RobotC, but is there a way to write text to the terminal? I want to be able to write a line somewhere, and then copy and paste it elsewhere. I figure that the terminal would be the easiest way to do it. Could anyone help? This is the code:
/*    Module:       main.cpp                                                  */
/*    Author:       C:\Users\jacks                                            */
/*    Created:      Wed Jun 26 2019                                           */
/*    Description:  V5 project                                                */
#include "vex.h"
#include <iostream>
using namespace vex;
using std::cout;
using std::endl;
// A global instance of vex::brain used for printing to the V5 brain screen
vex::brain       Brain;
// A global instance of vex::competition
vex::competition Competition;
vex::motor LeftDrive1 = vex::motor(vex::PORT20);
vex::motor LeftDrive2 = vex::motor(vex::PORT10);
vex::motor RightDrive1 = vex::motor(vex::PORT1, true);
vex::motor RightDrive2 = vex::motor(vex::PORT19, true);
vex::motor Tray = vex::motor(vex::PORT18);
vex::motor Arm = vex::motor(vex::PORT7, gearSetting::ratio36_1, true);
vex::motor Intake = vex::motor(vex::PORT8, true);
vex::motor Intake2 = vex::motor(vex::PORT9);
vex::controller Controller1 = vex::controller();
int loopNumber;
bool upPressed = false;
bool downPressed = false;
bool startedRecordingTimer = false;
bool startedRecording = false;
void startRerun() {
  if(upPressed == false) {
  Brain.resetTimer();
  startedRecordingTimer = true;
  upPressed = true;
void stopRecording() {
  if(startedRecording == true) {
  downPressed = true;
bool driveTrainReversed = false;
void changeDrive() {
  driveTrainReversed = !driveTrainReversed;
void stopAllMotors() {
  LeftDrive1.stop(brakeType::brake);
  LeftDrive2.stop(brakeType::brake);
  RightDrive1.stop(brakeType::brake);
  RightDrive2.stop(brakeType::brake);
  task::sleep(1);
void forward(float inchD, int speed) {
  float distance = (inchD * 27);
  LeftDrive1.rotateFor(distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  LeftDrive2.rotateFor(distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  RightDrive1.rotateFor(distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  RightDrive2.rotateFor(distance, rotationUnits::deg, speed, velocityUnits::pct);
  task::sleep(1);
  stopAllMotors();
void reverse(float inchD, int speed) {
  LeftDrive1.rotateFor(-distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  LeftDrive2.rotateFor(-distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  RightDrive1.rotateFor(-distance, rotationUnits::deg, speed, velocityUnits::pct, false);
  RightDrive2.rotateFor(-distance, rotationUnits::deg, speed, velocityUnits::pct);
  task::sleep(1);
  stopAllMotors();
void turnLeft(float inchD, int speed) {
  task::sleep(1);
  stopAllMotors();
void turnRight(float inchD, int speed) {
  task::sleep(1);
  stopAllMotors();
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the cortex has been powered on and    */
/*  not every time that the robot is disabled.                               */
void pre_auton( void ) {
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous( void ) {
//11.7 inches for a 90 degree turn
//Set the motors to brake
LeftDrive1.setStopping(brakeType::brake);
LeftDrive2.setStopping(brakeType::brake);
RightDrive1.setStopping(brakeType::brake);
RightDrive2.setStopping(brakeType::brake);
//go forwards for 50 inches
forward(50, 85);
task::sleep(250);
//turn left
turnLeft(11.7, 50);
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol( void ) {
  Controller1.ButtonA.pressed(changeDrive);
  Controller1.ButtonUp.pressed(startRerun);
  Controller1.ButtonDown.pressed(stopRecording);
  while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
  uint32_t recordingTime = Brain.timer(timeUnits::msec);
  Brain.Screen.clearScreen();
  Brain.Screen.printAt(3, 80, "Timer: %d", recordingTime);
  Brain.Screen.printAt(3, 100, "Pressed: %d", upPressed);
  Brain.Screen.printAt(3, 120, "Recording: %d", startedRecording);
  //Motor brake type
  LeftDrive1.setStopping(brakeType::coast);
  LeftDrive2.setStopping(brakeType::coast);
  RightDrive1.setStopping(brakeType::coast);
  RightDrive2.setStopping(brakeType::coast);
  Intake.setStopping(brakeType::hold);
  Intake2.setStopping(brakeType::hold);
  //Tray angle
  float trayAngle = Tray.rotation(rotationUnits::deg);
  //Arm angle
  float armAngle = Arm.rotation(rotationUnits::deg);
  //Motor speeds
  LeftDrive1.setVelocity(100, velocityUnits::pct);
  LeftDrive2.setVelocity(100, velocityUnits::pct);
  RightDrive1.setVelocity(100, velocityUnits::pct);
  RightDrive2.setVelocity(100, velocityUnits::pct);
  Intake.setVelocity(100, velocityUnits::pct);
  Intake2.setVelocity(100, velocityUnits::pct);
  Tray.setVelocity(50, velocityUnits::pct);
  Arm.setVelocity(100, velocityUnits::pct);
  //Intake
  if(Controller1.ButtonR1.pressing()) {
   Intake.spin(directionType::fwd);
   Intake2.spin(directionType::fwd);
  else if(Controller1.ButtonR2.pressing()) {
   Intake.spin(directionType::rev);
   Intake2.spin(directionType::rev);
  else {
    Intake.stop(brakeType::hold);
    Intake2.stop(brakeType::hold);
  //Tray
  /*if(angle <= 0) {
   if(Controller1.ButtonL1.pressing()) {
    Tray.spin(directionType::fwd);
   else if(Controller1.ButtonL2.pressing()) {
    Tray.stop(brakeType::hold);
   else {
  else if(angle >= 900) {
    Tray.spin(directionType::rev);
   else {
  else {*/
   else {
  //Arm
  if(Controller1.ButtonX.pressing()) {
   Arm.spin(directionType::fwd);
  else if(Controller1.ButtonB.pressing()) {
   Arm.spin(directionType::rev);
  else {
   Arm.stop(brakeType::hold);
  //moving the tray back if the arm is up high
  if((armAngle > 300) && (trayAngle < 900)) {
  if(driveTrainReversed) {
   LeftDrive1.spin(vex::directionType::fwd, (Controller1.Axis3.value() * 0.05), vex::velocityUnits::pct);
   LeftDrive2.spin(vex::directionType::fwd, (Controller1.Axis3.value() * 0.05), vex::velocityUnits::pct);
   RightDrive1.spin(vex::directionType::fwd, (Controller1.Axis3.value() * 0.05), vex::velocityUnits::pct);
   RightDrive2.spin(vex::directionType::fwd, (Controller1.Axis3.value() * 0.05), vex::velocityUnits::pct);
   /*Brain.Screen.clearScreen(color::purple);
   Controller1.Screen.clearScreen();
   Controller1.Screen.print("Arcade");*/
  else {
   //Tank Drive
   LeftDrive1.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct);
   LeftDrive2.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct);
   RightDrive1.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);
   RightDrive2.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);
   /*Brain.Screen.clearScreen(color::red);
   Controller1.Screen.print("Tank");*/
  //Countdown to the recording
  if(downPressed == false) {
  if(startedRecordingTimer) {
    if((recordingTime < 1000) && (upPressed == true) && (startedRecording == false)) {
      Controller1.Screen.print("3...");
   else if((1000 < recordingTime) && (recordingTime < 2000) && (upPressed == true)) {
      Controller1.Screen.print("3...2...");
   else if((2000 < recordingTime) && (recordingTime < 3000) && (upPressed == true)) {
      Controller1.Screen.print("3...2...1...");
   else if((recordingTime > 3000) && (upPressed == true) && (startedRecording == false)) {
      Controller1.Screen.print("Recording");
      Brain.resetTimer();
      startedRecording = !startedRecording;
  else if(downPressed == true) {
    //stop the recording
    Controller1.Screen.print("Stopped Recording");
  //Loop once the recording starts
  if((recordingTime >= 50) && (startedRecording == true)) {
    loopNumber++;
    cout << "Loop Number:\n" << loopNumber << endl;
    Brain.resetTimer();
    Brain.Screen.printAt(3, 140, "Loop: %d", loopNumber);
  //Once the recording starts, reset the timer every 50 miliseconds
    vex::task::sleep(20); //Sleep the task for a short amount of time to prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
    //Set up callbacks for autonomous and driver control periods.
    Competition.autonomous( autonomous );
    Competition.drivercontrol( usercontrol );
    //Run the pre-autonomous function.
    pre_auton();
    //Prevent main from exiting with an infinite loop.
    while(1) {
      vex::task::sleep(100);//Sleep the task for a short amount of time to prevent wasted resources.
std::cout and printf should both work, assuming you are connected to the robot or controller and looking at the terminal tab.
Assuming you are having the same issue you mentioned in this thread last week, please post your code (remember to wrap it in [code]…[/code] tags for formatting!), otherwise it’s very difficult for anyone to help you fix it.
I’ll edit this original post to add it, but this is the code:
#include "vex.h"
#include <iostream>
using std::cout;
using std::endl;
vex::brain       Brain;
int loopNumber;
void startRerun() {
  Brain.resetTimer();
  upPressed = true;
  downPressed = true;
  task::sleep(1);
  task::sleep(1);
  stopAllMotors();
  task::sleep(1);
  stopAllMotors();
  task::sleep(1);
  stopAllMotors();
  task::sleep(1);
  stopAllMotors();
forward(50, 85);
task::sleep(250);
//turn left
turnLeft(11.7, 50);
  while (1) {
  //Motor brake type
  //Tray angle
  //Arm angle
  //Motor speeds
  //Intake
  else {
  //Tray
  /*if(angle <= 0) {
   else {
   else {
  else {*/
   else {
  //Arm
  else {
  else {
   //Tank Drive
      Brain.resetTimer();
    loopNumber++;
    Brain.resetTimer();
int main() {
    pre_auton();
    while(1) {
Well, the call to cout in your code looks reasonable, but there’s a lot of complexity elsewhere in the code. The next thing I would suggest is to write a “Minimal, Complete, and Verifiable Example” (MCVE) to test just printing to the console, for example:
#include "vex.h"
#include <iostream>
int main(){
    std::cout << "Hello, World!" << std::endl;
See if this program is able to print to the terminal; if so, the problem is elsewhere in your code.
I tried it and nothing is displayed in the terminal when I run the code. I am running it with the robot and controller connected to the computer, and I have the terminal tab open.
Both at once? Not sure if that’s an expected/supported configuration, maybe try with just one or the other connected.
Other than that, I’m not sure why this wouldn’t work - maybe @jpearman can offer some additional insight?
