Zip Tie Question
In the VEX global game manual I couldn’t find what I was looking for on zip ties are we just restricted to cable and tubing management? Or can we also use it for general securing of parts?
Per R 19 in the game manual teams are allowed to use “Plastic zip ties no larger than 12” long and 0.25" wide." It does not restrict their use, so you should be able to use them for anything.
Well, if it is in size, and is vex legal zip ties. Then you can use it on your bot for anything. You can build a bot with out and screws or nuts and just have zip ties. If that helps with your question.
Yes that helps a lot thank you
So just to be clear, we can use zip ties as a brain or sensor if we want to? This is genius btw.
