Ahh ok thanks so much for answering these questions its extremely helpful for us first year teams.
Sorry, it seems I’ve misworded my question.
I was trying to ask why you made the shafts intersect?
oh, just because that way I could run shafts across the whole lift without them getting in the way of the conveyor.
You could probably get a much easier but maybe a little less grippy alternative by simply wrapping foam around a 60 tooth gear, or tread around a 24 tooth sprocket and foam around that. That may give you more traction than a standard traction wheel, although maybe not as much as the flex wheels.
I kind of doubt that. Foam has a lot of compression, but it doesn’t feel very grippy. And I’d bet it would disintegrate very quickly if used like a tire.
Thanks but I want to know how you powered how you powered your lift and where you put the motor and what gear did you use. PLz thanks btw.
The bottom bar of the 6 bar is being powered near the base of the towers by a motor, on a 1:7 gear ratio (motor drives a 12t gear, which drives an 84t gear attached to the lift)
I also have another question. On the top of your bar lift i see that it is connected by a thick shaft but there are no gears on the thing which connects to the bottom 84 tooth gear. Why?
The lift is being driven by the bottom bar, the shaft on the top bar exists only to provide a solid axis for the top bars to rotate around.
Oh ok thanks a lot!!!
I realize that you guys are not using drive shafts for wheels. What is the purpose of this and how to construct one?
we use screw joints instead of shafts for everything but the driving gears, which need shafts to interface with the motors.
It’s just a 2.5" screw that all the wheels and gears can free-spin on. I had to drill out the holes on the low strength gears.
I didn’t even think about using those things as wheels until i went to volunteer at an event this week!
I thought I’d share a recent upgrade (potentially) to the robot.
It’s a pneumatic tall goal scorer for use with the 3 preloads. Has very limited applications, but in a situation where I don’t want to use my preloads during autonomous for the win point, such as elims or when I don’t do solo AWP routes, this could be the deciding factor if the match is close. If I chose to rush the center goal, I could likely keep it upright and secure the entire match, waiting until the last 30 seconds to pop the 3 preloads onto it for an additional 30 points. This might be a very good way to make up the goal defecit if your opponent decides that they don’t need to double park.
It also might have some application is skills, if I can use it quickly enough.
And it can also do this:
Another use could be in Live-Remote-Tournaments (LRTs), where the overall lack in defense will ensure that robots can score rings on the high goal without any interference. I honestly think we might start seeing more high goal scoring mechanisms in LRT-focused robots, and even on some specialized skills robots too (especially if they cannot park as you previously mentioned).
I think skills would be a really good use for it. Putting down 3 preloads for thirty points is more efficient than 10 whole rings on the alliance goal
99999v, I have a more of a coding question. We are coding the auton and we manually set up the motors for the drivetrain instead of using the in built drivetrain function. I want to know how to code the inertial sensor so that the robot is accurate in going forward/brackward and in its turn? Plz help? Our competition is this sunday so plz help? Thanks!!
I got this question because i saw your video on programming skills and you guys were really accurate.
Why don’t you just use drivetrain?
we used a custom PID control loop for our turns based on the inertial values.
you probably don’t have time to learn this before Saturday though, so I would recommend using the drivetrain turning either with inertial or encoders for now and learning this way afterwards.
