Cursed Images
midnight snack
Omni Wheels - VEX V5 General Discussion - VEX Forum
I have nothing to say
There are so many thing wrong with this image
The rotating cap on the end of the Eklind screwdriver is missing. (Totally not anything else in that pic)
Listing all cursed things:
Keps nut
hex screws
One screw for mounting the bearing
non symmetrical pattern for locking omni
using a hs sprocket and chain for power transfer(iq chain and gears are better)
axle joint
4" wheel when everyone knows 3.25 and 2.75 are meta
using linear slide rail
standoff that connects to nothing
too small of sprocket so there is no connection to be made between wheel and sprocket to reduce wheel slop
Encoder mounted between the two drive rails when it should be mounted outside of them.
using a 5 wide on the inside drivetrain c-channel, only use 3-wides and 2-wides.
appears to be pretty loose chain
keps nut on the outside when it should be in the ‘c’ of the rail
Alright a lot of these are grasping at straws, but why this?
DALL-E Mini has an interesting interpretation of Spin Up…
The GDC has spoken
There’s only one way to clean up this mess…
Carefully and methodically?
Nah, use a magnet.
with 6 people and 30 minutes gone, reduced to atoms? Not speaking from experience he he he
I misunderstood the instructions
You created a portal to the Vex dimension
Dr. Strange, into the multiverse of cadness
This is the greatest spell of All Time
Intake reveal
The real debate is… flow or attack mode?
ben what did you do to that poor flex wheel i dont think we can be friends anymore
I agree with Taran what did you do to the flex wheel
